Now I can't hear the vocals
danielbea122
CarAudio.com Exclusive
After adding all the bass my mids/highs are still just stock so figured I'd order the little taramps ts400x4 with some midrange and tweeters.
I have a kicker 2 chan LOC. Would I need another one to run a 4 chan amp?
If I'm correct I can order 4 8ohm speakers and wire to 2 ohms but I'm not sure. So what would be best to run with that amp?
You need a better LOC like an LC7i or even better a DSP or headunit. The TS 400x4 is a very small low power amp so don't expect alot out of it. 50 watts per channel at 4 ohms. Two mids and channels 1/2 and two tweeters on channels 3/4 would be your best bet.
Yeah just wanted a little power than stock to make it sound better in the car. plus I don't want to be pulling much out of my electrical.
Not changing the hu in this vehicle but if you think I need a better loc than that I'll do
So after some research I have decided to add some 6x9s bridged 200 Watts RMS x 2 @ 4 ohm. Easiest to install for me plus I have the amp already.
Any suggestions on what I should add that will sound decent with all the bass? 2way, 3way or coax?????
Taramps are designed to be small. Amps like Power Acoustik are designed to be big so that people think they put out decent power. Open it up and you'll see what I mean. You'll get more than rated power all day from the Taramps, you'll be lucky to get half of rated power from the P.A. If companies like P.A. didn't grossly overate their products then they'd be taken more seriously.
Amps like Power Aoustik are be signed to be big so that people think they put out any decent power. Open it up and you'll see what I mean.
I still watch this video for entertainment from time to time... lmao.
20" of heatsink with 6"-7" of board ... smh
That's ^^^ an extreme example I know, PA ought to at least have a full length board inside the sink... I hope
Yeah now I know it's crap now but when I bought it used from a pawn shop I didn't know the difference between 2ohm and 4ohm subs lol
Learned a lot from you guys about subs but the speakers seem even more confusing with all the brands/models etc
Anyways, anything has to be better than these sad excuse for 6x9s
danielbea122
danielbea122
Tampa
Timbo74
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
