Is it normal for battery voltage to drop this much?
Josh Dubin
So I'm having an issue with my system. At high volumes, the voltage at my battery is dropping from ~14V (with no music playing) - ~12.5V. Is this expected for an 1100W amp? If not, would this indicate that my battery or alternator is failing to keep up? I got my battery tested and it says it's fine but I'm not 100% sure that that test applies when you have an 1100 watt amp.
Thanks,
Josh
So you are using a multi-meter at the battery terminals while playing music where the amp wiring is coming from?
Remember all Lead acids usually have a resting voltage of around 12-13V...AGM batteries can rest at around 13 or just under.  The Alternator is what brings the system up above 14v.
Well I've measured the voltage at the battery terminals and at my amp, with and without music, with the car on and off. With the car on, no music, voltage at battery terminals is about 14V. Once I start playing loud music, voltage drops to as low as low 12's, at battery terminals. Is this type of drop normal,  or is there an issue? And would this issue be the alternator ?
You have an issue. What amp is it? What car/alternator current rating do you have? What subs and ohm rating being used?
It's the alpine mrx m110. 1100 watts. I have an infiniti g37. I believe it's rated at 150 amps. I have a single dvc 4ohm sub, wired to 2 ohms.
If my voltage is dropping significantly when the sub is hitting hard, would that imply my alternator is on its way out?
im not familiar with that vehicle...but 150A alt. should have no problem with that amp, i doubt your seeing full power from it also...my amps in my jeep are capable of 2000 rms and i have 160A alt. never had a problem with voltage even before upgrading electrical (big 3, dual batteries).....throw a decent AGM under the hood and do the big 3....see what that does.....also check/clean all your grounds
Josh Dubin
Josh Dubin
YourNameHere
