can i run two different amps for 5 speaker setup?
mistafisz
Im thinking of running 2 different amps in my car for 4 speakers and a sub. Is this possible to do? First amp would be a mono 1100w, 400rms at 4ohms for my 10inch, 4ohm, 150w rms sub. second amp is 4 channel 1200w running at 150wrmsx4 channels for my 2 100w rms coaxial and 2 100w rms components. My head unit is a kenwood kdc bt558u. I fairly new to audio systems in general, any help and explanation is appreciated. thank you.
yes, you can run 2 amps. for that matter, you can run 10 amps to 5 speakers technically. Or 5 amps to 5 speakers, or 3 amps to 5 speakers etc etc etc. Most folks get a decent 4 channel for the fronts and rears and a mono for the sub. some folks get a sturdy 5 channel for all of em. The real answer is very long and very short at the same time
Can you run multiple amps? yes
should you? probably
from there your wiring, battery, grounding etc etc all comes into play and we can help you with all that too
Thanks a lot! I ended up buying a 4 channel for the front and back speakers and a mono for the sub.
mistafisz
mistafisz
youdoofus
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
