Hissing coming from amp even with no RCA input
gmpisawresome
Junior Member
I'm finally at the end of my build, and while everything is installed correctly, I still have a high pitched hiss coming from the tweeters. The speakers are morel Maximo 6 hooked up to a Kenwood kac-304 bridged @4 ohm. The RCA is hooked up to a Kenwood ddx9903s. Even when the RCA is unplugged, I still get a hissing noise from my amp. From about 0-75% gain the noise is the same but above 75 it starts to get louder; I have my gain on ~50%. I have a good ground I think, and even hooked the amp straight to the battery to test and it still hissed. Any ideas?
Thinking you have a good ground wouldn't hurt to check anyway. Bare metal to bare metal. Most noises are caused by bad grounding points. Oh dam. Didn't read your last sentence. You may have a bad amp in your posession.
I might just be wanting it to be too perfect. What is an acceptable amount of static from an amp? It's almost drowned out by my cars idle (little Toyota 4 cyl) but you can still hear it if you listen.
Just when you think you're humming along... and... hmmmm happens!
22
Decibels are a measurement how loud something is...it's not the frequency of hearing...
19
I'm getting a whining noise from my one speaker anytime something in the truck activates. When lights are triggered to turn on. Happens when the...
Maybe/maybe not. First it's just a guess, but components can change value with temps and this could be normal. Could also be a sign of a cap on...
gmpisawresome
Junior Member
gmpisawresome
lakeland fl
youdoofus
