Mid range.
https://www.ebay.com/itm/FOCAL-AUDIO-13HP-OEM-5-25-MIDRANGE-4-OHM-MIDBASS-SPEAKER-CAR-HOME-MID-NEW/120605797656?epid=1739042286&hash=item1c14aa6d18:g:KHwAAOSwYGFUtXxS:sc:USPSFirstClass!75189!US!-1
Id prob throw something like these in there if it were my vehicle.Rear fill off deck power should do fine.Just an option to look at. im sure others will chime in with other options
Alright thanks, but is there any disatvantages of getting component speakers and running just the woofer thru the crossover? Or even without it? Because I would just like to stick to one brand for my build weather it be pioneer or alpine wich is mostly common in my country.
Only disadvantage is not getting full range without the tweeter as most mid drivers that come with comp sets can play full freq, but arent very good at it.
oh, and use the high pass filter in your deck, not the passive x-over
Yeah alright but won't the tweeters in the front be enough to get the full range in the car stage? Basically just looking to fill the rear void
Parts express has pre assembled low pass crossovers you could run in line and use your high pass on the hu for the low end and the lp passive for the high end . They have quite a few different options (frequency cut off points) 4 ohm or 8 ohm and they are cheap. You really don't want high frequency on mids won't sound good.
Reinholds Sturiska
Reinholds Sturiska
fithwheel
