Rear speakers not working, help!
GabeDahlinghaus
I installed an aftermarket stereo into a 2007 Honda Accord. It powers on and the front speakers work, but the rear speakers are silent. I’m not sure if it has to do with a factory amplifier or something like that. And I made sure all the connections were correct and secure. Please help!!
very unlikely a factory amp issue otherwise the fronts wouldnt work either. double check the wiring schematic to find what the RR + and - and LR + and - wires are to connect to the harness. You probably have a couple of them switched up
I’ll check on it. That’s most likely the issue. Thanks bro.
this is of course assuming that you have a conventional aftermarket head unit hooked up to an adapter molex plug wire harness directly, no external amp or anything like that
All wires are correct; rear speakers still don’t work. I even reconnected the rear speaker wires and no sound. The speakers themselves worked fine right before I installed the after market stereo.
what about the fade? or even an on/off setting for the rear speakers? can you test them with another speaker like a small home audio speaker?
I set the fade to mostly rear speakers and no sound. I already tested the rear speaker wire outputs with a test speaker and there was sound from the test speaker.
Pull each speaker in the rear and test with an Ohm meter/DMM and see what the value is.If they are 2 ohm stock speakers they should read around 1.9-2.3 ohms. Same area for a 4 ohm speaker..3.9- 4.3 ohms. If readings are all over the place ,,speakers are no good/ blown
Ok, I’ll check back with you once I get the results.
you can also leave the speakers in the rear deck and test them without speaker wires connected to them
I tested the rear speakers with a multimeter and I didn’t get a reading, does this mean they are dead?
Sounds like an open circuit so yes... if you don't trust the reading use a 9v battery on the speaker leads and if it won't move they're toast. (coil or tinsel leads failed)
GabeDahlinghaus
GabeDahlinghaus
GabeDahlinghaus
NorthFramingham
    Jun 30, 2026
