Most Efficient Amp Ever? Brutal Sounds BS5.1
With the video on YouTube showing the Brutal Sounds BS2.1 putting out like 90%+ efficiency and this post from the Brutal Sounds Facebook page, is it safe to say these are the most efficient amps ever tested? Either that or these are magical. 240 amp draw with nearly 5k watts? I dunno what do you guys think?
 The picture shows a 5.1 but if it was the 2.1 I know there was a video someone did of 2 2.1 clamped and it drew 240 Amps but that is x2 so it’s really 480 amps
yep, well over 100% efficiency.  It should put out power without even having the power wire hooked up.
Can't believe no one is calling them out on this.
i was kinda wondering if they had discovered how to do cold fusion and applied this scientific discovery to the world of car audio instead of like powering small cities ?
I'm lost myself. The 2.1 had like 90% + efficiency numbers so I dunno. That video was the reason I got the brutal sounds 5k instead of the Orion HCCA 5K. The Orion certainly puts out more power like 3k RMS more.
Should be drawing 347.222 amperes of current. How is it possible that they're getting far less than that??
Paging TaylorFade....you have a call on extension 2385...
That's Facebook for you. The amount of absolute stupidity there is waaay more than I can handle. At the same time I guess that's why some people like it so much. If you're the only non window licker in the room then I guess it makes you feel kinda smart.
Horn would be the most efficient. Ported would be efficient and easier.
Okay I am seeing two possible ways to connect a sub with HU and amp depending on their construction (there maybe more but I'm a newb). I also have...
Some high power offerings and much appreciated. When buying an amp that offers much higher power than the speaker ratings, I assume that I will...
65
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
230
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
276
8 Inch Vince
Milwaukee, WI
8 Inch Vince
kanihoncho
    Apr 28, 2024
kanihoncho
    Apr 28, 2024
