Distoraton at low volume levels using pioneer speakers and JVC Head unit
nice! 3 pairs of pre-outs at 5, COUNT EM 5 VOLTS!!!, 13 band eq, time alignment, etc etc. those old pioneers might have got smoked from something with the way the old setup was rigged, but im glad to hear that you got it where you want it :)  cheers sir
It sounds amazing now! Saving up and will probabaly run 2 15s in the back from kenwood lol
good show old chap! what vehicle is it? also, to help us all out, you should add some vehicle specifics in your signature so we dont have to bug you 100 times asking what car, amp, deck etc etc etc. I ask because unless you have a yukon, 2 15"s wont be ideal. 1 15" in the right box will astound you vs 2 of em in whatever you can wedge in there
I went to my profile and added missing information. Don't know why it only shows my location on my posts. Thanks man. The car is a small suv. I have tons of room in the back lol
My JVC kdr995bts is randomely freezing and wont turn on for a day at a time. if I reset it it MAY come on but then freeze again so I put my kdr680s in. What is wrong with it or could cause this? when it freezes even turning off my car wont turn it off. when it wont power on the usb I play from still has power...
Nevermind got it swapped out with a replacement. The old unit was defective. Still a jvc-kdr995 bts.
Nice. I just installed a KD-X360BTS.
This thing has more features than I'm used to. Has a speaker size and sub size selection not sure what that does.
what ^ said. amp gain setting info, test tones are at the very bottom...
454
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
621
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
maq1919
maq1919
Warwick MA
maq1919
    May 20, 2024
    May 20, 2024
