Sundown single 10 install with a pbr 300x1
I hope you got a dual 2 ohm sub.
If you do wire all the positive together and connect to the amp and do the same with the negatives.
If you have a dual 2 sub that results in a 1ohm load
If you have a dual 4 sub results in a 2ohm load
If you have a dual 4 sub results in a 2ohm loader
It’s a dual two ohm. So you mean one wire negative to negative and one wire positive to positive. And then connect one of the terminals to the box?
Take the negative wires from both sides of the sub and run them to the negative on the amp then do the same with the positive.
All the positive need to connect and all the negatives need to connect
customlt1
customlt1
buffalo,ny
michigan born
    May 14, 2026
michigan born
    May 14, 2026
