Kicker solo baric 15" (round)?
  • 3
SharpCodex
CarAudio.com Newbie
10
Hey guys! im thinking of getting myself kicker solo baric in my car. do you guys have any opinions on this sub. how does it sound? im trying to go budget, il get it all for like 80$ (including sealed box and amp) Thoughts? :D
This will just be something i have for a few months intil i get myself a job (i go to school rn, and i have alot of distance to cover ocationally)
@Popwarhomie Is it that bad to buy an old sub? if it works fine? also is blaupunkt any good? :)
The walmart Blaupunkt subs are quite good for the money and are some of the best subs you can get for under $100.
Infinity ref series/JBL club series are also good performers for the money.
Its ok to buy old subs if they have been taken care of. Kickers are usually owned by noobs that don't know what they are doing so they will be more beat up than higher end equipment.
Thank you! :D  is there any good ways to check if the sub is fine just by looking at it, or is it more internal? (Im a noob)
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
516
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
SharpCodex
CarAudio.com Newbie
SharpCodex
THATpurpleKUSH
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
