Speaker to amp help
  • 2
Kicker75
Hello all, Excuse my lack of knowledge as I am just a beginner in car audio. My question is this, I have a 4 channel amp that puts out 75 watts per channel at 2 ohms. If I wire 2- 4 ohm speakers in parallel to one channel does each speaker get 75 watts,or is the power split between the 2 ?
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep...
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
For the sub/amp combo, you can use one voice coil per channel. So no need to use the jumpers of the sub. As for the co-axials, you can bridge...
Kicker75
Kicker75
Kicker75
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
