CLIPPING indicator
if you're handy with circuits and soldering you could connect an LED to a high pass filter that was powered from the amp output.  Clipping creates high frequency harmonics that are above 1kHz even with an 80Hz LPF on the amp.
All you would need is a 12v led? Ive done the clipping test with a tweeter before but never with an LED. I figured an led would stay lit the whole time the amp is feeding power or pulsating to the sinewave
note the high pass filter requirement.  a 1kHz HPF or 5kHz HPF would cause the LED to illuminate only when clipping was present.
Video on clipping harmonics and what that looks like:
Circuit for powering an LED directly from an amplifier output (in which case it would pulse like you describe:
Cool deal, ive been using the tweeter and low pass method for a good while with great results. I'm honestly prolly leaving power on the table with how conservative I am.
I'll prolly buy the new audio control rta when it releases and double check everything but it's been set up for over a year so it close enough for now
Why don't you trust them? It's a very simple circuit compared to the rest of the amplifier. The clip light for my orion amp was spot on with my...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
558
Don't recall off hand. Both single dins. One excelon, one not.
900
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
10
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
5K
Clifford audio
Clifford audio
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
