Protection mode flickering but amp doesnt always shut down
  • 2
Robert24z2
CarAudio.com Newbie
Ok I will start with what I have. I have 2 Orion HCCA 124's bridged to 2 ohm. Kicker cx1200.1 mono amp. All 4 gauge power and ground. Stinger 2-farad cap and 150 amp breaker. Gain on amp is a little under half way up. I have my LOC tapped to my factory subwoofer line and since there is only one sub, I tapped the 2 positive inputs on the LOC to the one positive line going to the sub and same for negative. (not sure if anyone has done that)
Here is what's going on...First, my breaker keeps tripping at loud volume and as I looked deeper into it I notice that the protection mode light on the amp flickers when the bass hits. The amp will continue to play while the light flickers until turned up loud the amp protection mode kicks in a shuts down for a few seconds then comes back on fine.
so far I have tried bypassing the capacitor and the breaker with no luck. I have verified solid, correct wiring on the subs. Any advice would be great!!
When it is playing loud, have a volt meter on the positive and grounds at the amp. I bet they are dropping to 11v or lower.  If they are check that your ground cable is in a good spot.
I had a cxa1200.1 actually I had 2 of them at one point.  First one that I owned did not like going below 11v for obvious reasons but I had only a front Lead acid battery. Soon I up'd that to an AGM group 27 or whatever could fit my car. That helped a bit but once I put a group 31 agm in the trunk I never saw the protect light again.
Ok thank you, I'll check where the remote wire is connected and get back to you.
823
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
8
Make it look nicer. Carpet it up with black. It will look like a speaker. The wood look is not good at all. Don't look too professional. What...
39
5K
Not much user serviceable about an amp powering up into protect with nothing else connected. Send it back for repair/exchange or whatever they do...
Thank you for the info and advice. I really appreciate the help. I will double check my wiring tonight or tomorrow.
20
4K
Robert24z2
CarAudio.com Newbie
Robert24z2
nate0
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
