Help with Build
  • 2
CodyDaGoat
6
OR
Hello, just looking for some advice on my build ill be working on.
Currently have 2 Orion HCCa152 Subs. I have the 2ohm ones at 2,500w RMS each.
I was wondering if anyone knew of any good amps that can run 5000 watts at 2ohms
THe biggest alt I can get is 270A and ill be buying from either Mechman or Singer.
And my second question is, how many batteries should I expect to run with this buiild, and which ones will be best?
I have a custom box built for my car. I have a 2010 forester. It'll be tuned to 28hz.
Would also like some recommendations on a mid/highs amp.
Thank you in advance
Why 2 ohms and not 1ohm or .5 ohm. An amp to push that at 2ohms is gonna be a pretty penny. But u could always get 2 amps and strap 'em, be ur 2ohm and probly less costly than one amp that can push 5k rms @2 ohms.
Wolfram amps are good.
I had this potential one
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
855
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
790
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
7
I'm in the same boat and have a few posts on several forums so this is NOT advice but just sharing what's going through my mind and we can help...
10
4K
CodyDaGoat
CodyDaGoat
OR
CodyDaGoat
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
