SUB WIRE?
  • 3
David Atkinson
CarAudio.com Newbie
What is the SUB wire used for? I bought an aftermarket stereo, it has a FL/FR and RL/RR RCA output for and SUB wire. I am running 2 amps, 1 for my sub and the other for my speakers. I am using the FL/FR and RL/RR RCAs, there is no RCA for a SUB, just a SUB wire.
Not able to blow up that pick .. but that wire looks like the REMOTE wire for externals/amps acessories/ON /OFF from what I can see.Follow the Manuel/ instructions of the product.I would give the manufacturer a call and ask directly. Could be a mis-print error
Would something like this work? https://www.crutchfield.com/p_204BTA1010/Bazooka-BTA10100.html
13
4K
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
253
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
341
The best shallow that I've heard is the JL by far. One good regular 8" sub on a 1K would probably be all that you need. Two 8's in 1.5 cubic feet...
11
475
David Atkinson
CarAudio.com Newbie
David Atkinson
hispls
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
