What brands do people like for speakers?
infinity, jbl, alpine, polk, even pioneer are pretty popular i have soudqubed coax they ok (u need hp xover for any speakers though either amp or on hu).. if u want super sq then look other pro audio mids and tweets especially if u have "active" hu
An amp crossover would be a pre amp right? What would you recommend?
i just mean hp xover on the amp.. either use that or get hu that has one they are easier to control from hu because u have a digital read out and easier to get to.. if u want best 4 channel cheap pioneer 8604 i think it is tested higher than rated.. i just have $120 kenwood x301 (new one is 302 i think) it has all xovers u need + 13 band eq, time alignment, 24 bit da convetor, bt, usb pretty nice for the $
This was the HU I planned on getting, it says it has high and low pass but I don't know how adjustable it is. Do you know how to tell or is it build into the eq?
i'm sure it's just like mine jvc/kenwood same company now.. xovers are totally different from eq.. it just says xover hp and then u got tweets/front/ rear/ sub and set them where u want them
Thank you, where did you get your wiring harness? I have an 05 Pontiac Sunfire (mostly the same as a Chevy Cavalier).
Nevermind I found one
it shows on pg 27 that it does have hp xover set that at 80 hz and if u ad amp to the speakers select off or full or bypass the hp xover.. just use the 1 on hu because it's easier to change and set, set at 80 play song drop down to 60hz if u hear distortion at all go back up.. it'll depend on what music u listen to and how loud u play it.. i just added $ foam speaker baffles to mine today and i can lower mine to 70hz instead of 100hz because it sort of acts like a box
I got my 360bts at Crutchfield. Got the Metra dash kit, wiring harness and antenna extension adapter for my car included
You can choose the slopes also if you choose a frequency. HP has two slopes and LP has four.
I just use the ones on my 8604 and GTR-1001 and set the deck to THROUGH on HP and LP. I may use the HP on the deck and turn it off at the 8604. No on/off switch on my 1001 so I will use the amp LP
Make sure you are 100% sure you won't be using CD's since the 360bts has no disc drive. I haven't used them in over a decade
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
9K
Wow!! Very interesting to see some of what I thought Id see in the Top 10??
15
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
4
187
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
370
Joel114
CarAudio.com Recruit
Joel114
shredder2
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
