door speaker static and sound issues
  • 3
Hello,
I recently wired the door speakers to the factory wiring with new door speaker wire, ran it straight to the back to hook up my amp which I didn't do yet. However, I have audio coming out of the front left door speaker but none from the others except static from the front right speaker. I know in my old car, once I unhooked the door speaker amp, there was no sound at all.
Anyway, how I wired it were the door speaker positives for a 2 channel setup, remote turn on to the remote turn to the radio and the remote turn on to the second amp.
Not sure what I did wrong or should I plug in the RCA's, power, speaker wire, and ground to the amp then see if it works as I have 2 RCA's in for the sub amp and 2 in for the door speaker amp.
What vehicle do you have,year and model ?Do you have an aftermarket radio installed or using stock radio?What amps are you running and what speakers are you running as well?
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
229
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
8
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
mobbdeep
mobbdeep
Tucson, AZ
keep_hope_alive
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
