8" sub recommendations
tooshort_128
I'm planning to install a budget system in my 2017 F-150 and finally want to try 4 8's. The box will be sealed and will have about .4 cubes per sub. My budget is at $200 so I was looking at some Skar IX-8s (cheapest option) and NVX VSW8s. Are there any other budget friendly 8's out there that will sound decent? I'm not concerned with spl but the lower they hit, the better.
if youre looking at 1.2 cu/ft sealed, why go with 8"s? you could get a very good 12 for around 200 and blow the 8s out of the water
I’ll have 1.6 cubes for all 4. Why not skar? Are they that bad? I’d be interested in the MB’s if they weren’t shallow. The subs will be under the seat down firing but don’t need to be shallow. Ive got over 5” of mounting depth to work with so full size subs will work. I feel like the shallows won’t have the excursion to hit the lows.
234
326
I'm with you there. Even a smaller REAL sub as @audiobaun has suggested would be preferable. The only spare tire subs that I've heard that make...
10
436
405
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
319
tooshort_128
tooshort_128
Sterling, VA
shredder2
Brendon Jenness
    May 8, 2024
    May 8, 2024
