Get a 2nd Battery or Replace the Stock Battery with a Bigger One?
  • 4
Rhythm
I think I'm in the home stretch with figuring out everything for my first system.
It's been more than 6 years that I've been going back and forth about buying a system, and I think I actually might pull the trigger!
One of my last questions is regarding an additional battery. I don't know if I should get a second battery to work with my stock battery, or if I should just buy a more powerful battery to REPLACE the stock battery with.
The system would be right around 1000 rms for a 2012 Civic LX when it's all said and done. I was told to steer clear of capacitors.
Any thoughts or advantages/disadvantages to either way?
Oh you're gonna be told to steer clear of caps lol trust me lol. Jump on a Big 3 upgrade and an AGM battery up front. I am sure the others will come in and agree.
Thanks - I've got another person telling me to invest in a HO alternator....is that necessary?
Steer clear of **** caps, that are under 20f and are one big cylinder.
Absolutely go for banks of maxwell or XS power ultracaps. They're 3000f and ~400-500f in a bank and make a massive difference, but you need to have a HO alt first.
Considering you are running 1000w you don't need a bank of caps, and you might not need a HO alt. Just some proper wiring.
depends on how many amps alt has mine is 125 and i run 1100rms no problems with agm start batt and big3 wires..
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
Rhythm
Rhythm
Chicago burbs, IL
BOOMINGRANDPA
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
