Port sealed double 15" subs
XxAndreaxX
spain
hi, like from the title, I want to port my sealed doublé MTX RT15 sub.
here comes the reason:
my car, is a sedane (alfa 159) and the only conntection between trunk and cockpit, is the gap of the rear armholder.
so my idea was, to drill a port at the rear of the box, that matches at the high of the gap to the cockpit.
I know, the encosure does not matches the litres for the 2 MTX to be ported, but with a Little bit of good work, it could sound better.
My first question is, should I go with 1 port tube or 2????
later on, I'll give you the measures of the box, to calculate the ports
thanks!!!
If the subs are facing to the rear and your port forward it'll have serious cancellation. Also, itll need double the volume of a sealed enclosure. I'd suggest you scrap the box and build a new one.
here's a picture of the trunk.
the speakers are firing out of the car, and as you see, the enclosure fits almost perfect to the trunk. the port should be on the other side, firing into the cockpit.
I can't build a bigger enclosure because of many factors, I have to find the best solution with what I have.
Bad idea. Sell the 15s, buy some 10s and build a 4th order for two 10s with the port through the ski hole.
no, i'll keep the 15", at worse case scenario, I'll stuff the port, and keep it sealed. you think i'll have much cancellation??? I've seen many home theatre subs with the port behind the cone and they do well. most of subs out there actually have the port opposite to the woofer. only caraudio has the port on the front for obvious reason, because on the back, you would seal the port with the back seats. in my case, the port woud match exactly to the hole that connects to the cockpit.
Another question I have, I've seen most of ported doublé woofer have divided enclosures, with a Wall beween woofers. is there any difference to play both woofers in the same enclosure??
thanks!!
no, i'll keep the 15", at worse case scenario, I'll stuff the port, and keep it sealed. you think i'll have much cancellation??? I've seen many home theatre subs with the port behind the cone and they do well. most of subs out there have the port opposite to the woofer. only caraudio has the port on the front for obvious reason, because on the back, you would seal the port with the back seats. in my case, the port woud match exactly to the hole that connects to the cockpit.Another question I have, I've seen most of ported doublé woofer have divided enclosures, with a Wall beween woofers. is there any difference to play both woofers in the same enclosure??
thanks!!
Get any kind of home theater logic out of car audio completely and never ever link the two together again.
Home audio you dont deal with cancellation and rear waves anywhere as close to what happens in a car environment. Home theater is literally EZ sound for dummies vs Car audio which has a lot more acoustical challenges going on in it. Whatever you think is good is basically complete garbage in actual real world results purely due to cancellation aka ZERO bass.
The only way any of this would even work would be to go down to two 10s and do a 4th order blow through. Your first idea of porting 15s with already a tiny sealed box is already beyond stupid because ported literally needs a box 2-3 times the size of your sealed to even properly perform. I'd highly recommend reading up on ALLLL the basics of car audio enclosures before screwing up your system even more. A proper ported box for two 15s would be around 7 cubic feet to 9 cubic feet NET meaning subtracting all the space the wood, bracing, subwoofer and port takes up. thats pure 7-9 cubic feet of airspace alone just for the sub to properly function and breathe. Your port needs to be big enough as well. for two 15s, you need at least a 6-8 inch aeroport. So yeah man, just leave sh*t as is. Or actually sell everything and do things right because all you are doing is shoving things that dont work in a small space like a big noob.
We already told you this months ago from your other thread but you didnt listen at all.
Dude that is way too much woofer cone area for the size of your trunk
---------- Post added at 10:59 AM ---------- Previous post was at 10:59 AM ----------
You are not fitting a ported box for both of those in that trunk that will sound remotely good fyi
I didn’t read everything but having a port in the back of the box isn’t a big deal. But the box is 2-3 times to small to port. Leave it sealed or sell and start over.
you are literally losing all sense of spl lately dude. That orientation only works in crxs doing a huge cone area burp setup.
guys, I managed to fit my sundown X8 in a 10L (minus the sub) round box, and port it.
The port was a total experiment, something like a 50cm long tuve, but guys, it souded not only much louder, but the port, was at the exact frequency I wanted.
So what I'm about to do is only an experiment, I was lucky with my sundown, so maybe i'm still lucky with this. and if it sounds crap, I'll seal it and problem over. 2 15", will sound strong even sealed.
It’s worked in trunks also.
I wouldn’t call a pair of 12s huge cone area.
Uhm try a pair of 15s or 18s in a CRX. i dont remember saying 12s.
Cancellation and interaction between front and incident waves in a trunk with lower frequencies is way more chaotic than in a hatch at a higher frequency.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
888
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
591
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
752
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
726
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
XxAndreaxX
spain
Jeffdachef
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
