Lossless files over bluetooth VS CD Quality
  • 6
tommymilan311
Senior Noob VIP Member
I've been noticing some lossless steaming options becoming available, and this sounds nice. LOL
So I've been researching to see when and what services are and will be available. I've been a spotify user for quite some time but quality is... meh. Rumor is they have Lossless quality available. Well in my car I generally only listen to CDs, sometimes I'll listen to spotify for variety but.. meh.
Well through research I see a lot of claims that "most can't tell the difference in 320kbs or lossless WAV/CD quality even with high quality equipment, especially in car audio." Well I find this very untrue! There is a huge difference from what is on my CD.. and the 320kbs stream from spotify.. like night and day. I've done back to backs on the same song... but I decided to dig deeper.. Some of the CDs I buy come with lossless WAV downloads... I decided to take that to the test.
What I found was the bluetooth stream seemed to be more of a factor than the actual audio.. the Spotify to WAV wasn't huge, though I thought the WAV still sounded better, that could just be subliminal reasoning.. but the CD was just so much more full and open as compared to the bluetooth stream.
Have any of you tried to do this comparison? Any ideas how to better get the quality of the music from my phone to the receiver? and perhaps a better receiver? It sounds like Spotify is going to have lossless streaming within the year, I'd like to be able to take full advantage.
Out of curiosity I checked the Bluetooth standards. Bluetooth version 3 (currently we're up to at least 5) has a maximum speed of 25 MBit/second, and newer versions are faster. Version 1.2 of Bluetooth could handle at least 700 KB/s. A CD rom at regular speeds (aka "1x") has a transfer rate of 150 KB/s. Comparing those numbers, it's highly unlikely that the Bluetooth stream itself is the culprit. If there is a difference, it's likely in software or processing of signal on the part of the receiver or transmitter.
But I'm spitballing here. A real computer scientist, ECE, or EE would need to chime in.
Cd plays at what is considered full volume due to direct play.
Bluetooth needs gain adjustment since you have to match device volume and headunit volume.
Also 320 and lossless wav are near identical.. flac is much more quality in comparison.
Sent from my Moto G (4) using Tapatalk
actually its more of a factor of, you need a different tune for your BT settings vs your CD settings. Do it right, they sound the same. You cant expect to use the same tune for CD as bluetooth, it doesnt work that way.
So I suppose the phone I'm using might make a difference? Probably not tho, cause its a Galaxy S8.
I did do a little bit of playing with volume levels and I found when I turned my phone down a bit.. like all the way down to the "damage your hearing" warning and then I turned my Input adjustment setting at the HU up... all the way up +4. It sounds a lot better, more clear and full. But its way quieter as compared to the CD. The problem is I think the is some internal compression going on with the phone beyond this volume.. I start to lose a full kick drum sound and my cymbals become washed (side by side comparisons).. I've played with the headroom that my head unit allows.. I generally do all my EQ settings from my processor, and it'd stink to have to have to different settings from the processor if I wanted to listen to CD vs Bluetooth
Also, the HU does allow different EQ settings for each input.
Samsung has preset eq's.
You need to root it and use viper4android to get a flat eq going and work the gains.
Is there still possibility that there is internal compression and distortion to make it sound louder when I go passed the "too loud" volume?
Viper4android is a dsp its self and controls how the output from the device will be like..
So you will want to tune it while at full volume.
no its just the internal dsp fking your sh*t up. I had to shut mines off when i tune as well, my phone's dsp actually was boosted so it was actually louder than CD/USB and caused some premature clipping.
Are there any ways to fix this without rooting my phone? all method for the GS8 are sketchy as can be
Sketchy? Its just odin with a zip containing root, but no there is not
From what I read.. the Galaxy 8 has fail safes that prevent you from setting it up properly.. I have never rooted my phone because I haven't known what exactly I'd do with it. I'm seeing a lot of folks get stuck in boot lock.
Stream? Unlikely https://www.smsl-audio.com/portal/product/detail/id/809.html https://helmaudio.com/products/boltdac You might can stream in...
I think in order to play video it needs an hdmi input. My jvc is supposedly able to play video yet dvd is the only format.
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
So? Just use winzip or something like that and they work just fine. I have that same set and did that with no issues. There is also this link and...
4
945
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
444
tommymilan311
tommymilan311
Davenport, IA
HardcoreBob
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
