Tuning Car set up first time
neil4374
After along time of installing my set up. I about to embark on setting up the amp for the first time. Now, I have researched this and understand it pretty well. However I have a question relating to this and running speakers in.
All the guides I have read have said to set the head unit volume first with the amp gain very low.When I hear distortion to back off the volume to the sound is good. Then on with the amp gain and do that, I understand this however my friend told me not to go over 50% volume or gain so as not to damage the speakers.
How can I set up the system without going over 50% volume on the head unit or 50% gain on the
amp?
Is it acceptable to set it up going over 50% and then reduce it for a few months till the speakers are run in or is the 50% an absolute must?
Thanks
pretty much no sense. i mean its not a bad recommendation but its not accurate information. most CD players will clip around 3/4 full volume. some way earlier. like that ****** alpine 149.. if you don't have a way to test output its a safe bet not to go past 3/4 volume and set hte gain according to the input from the source unit.
when you hear distortion back down at least 4 clicks. chances are you are hearing 20% distortion..
Thanks again for your advice:)
So your advice matches hat I have been reading about.
But do you agree that the amps gain on any channel shouldnt go above 50% in the first few months. Or is that overkill.! Sorry still a bit confused!
Thanks again for your advice:)So your advice matches hat I have been reading about.
if your CD player has a 4 volt preamp outputs turn the gain knob to the 4 volt make and you will be fine.
If your amp is like most it accepts up to 6v. If you have 4v preouts that mark is around 1/4. If you have 2v preouts it's around 1/2.
50% gain isn't 50% power.
Check your amp and see what's the highest input voltage it accepts. Then check your HU to see what's it's preout voltage
most modern head units go up to 90 to 95% without clipping or distorting nowadays. that 3/4 rule is for old crappy head units that actually distort. Every modern head unit i've come across is clean 39/40 or clean at max volume.
That's what I figured too but look into the Alpine high-end units. 1.9 volts poo..
Most good modern decks.
Sorry guys, I am lost!!
4 volt mark?!
Please would you look at amp and head unit. I have know idea about volts.
Much appreciated:
Amp
https://www.rockvilleaudio.com/rxh-f5/
Features:
Rockville RXH-F5 3200 Watt Peak/1600w RMS 5 Channel Car Stereo Amplifier
CEA Compliant Power Ratings:
4 Ohms: 550 Watts (4 x 50 Watts + 1 x 350) at 4 ohms and 1% THD+N
2 Ohms: 800 Watts (4 x 75 Watts + 1 x 500) at 2 ohms and 1% THD+N
RMS Power Ratings
4 Ohms: 1100 Watts (4 x 100 watts + 1 x 700 Watts)
2 Ohms: 1600 Watts (4 x 150 watts + 1 x 1,000 Watts)
Channels 1 through 4 are class A/B and channel 5 is mono class "D"
High-Speed MOSFET Power Supply
Studio-Grade Bipolar Output Stage Transistors
Fully Adjustable 12dB / Octave Crossover with Differential Circuitry
CH3 & CH4 Low Pass 500Hz - 3KHz
CH5 Low Pass 50Hz - 250Hz
CH3 & CH4 High Pass 50Hz - 1KHz
High Level Input Auto Start Smart Turn-On
Full IC-Controlled Protection Circuitry
Remote Dashboard Subwoofer Control
Fully Adjustable Bass Equalization Control
2 Ohm Stable Stereo
4 Ohm Mono Bridgeable
3 Channel Mixed-Mono Capable
Channel 5 - 2 Ohm Mono Capable
2 CH / 4 CH / 5 CH Input Mode Selector
Fully Adjustable Subsonic Filter: 15 - 50Hz
Crossover Bandpass Control
Subwoofer Phase Control
Mute and Delay Soft Start System
8 Volt Preamp Circuitry
ELNA Brand Audiophile Quality Capacitors
Status Mode LED Indicator
Minimum THD at Rated Power:
S / N Ratio: > 100dB
Frequency Response: 10Hz - 40KHz
Damping Factor: > 200 @ 100Hz
Dual 60 Amp Maxi Fuse
Dimensions: (W x H x L) 8.5˝ x 1.8˝ x 16.1˝
Owner’s Manual
Headunit:
https://www.manualslib.com/manual/696881/Jvc-Kw-R710.html
Hands-on research
Features and Specs
Expandability
AUX Input Front
Audio/video Input ---
USB Input Front
CarPlay No
Android Auto No
Siri Control No
Android Control Yes
Memory Card Slot USB memory
Bluetooth Compatible No
Satellite Radio Ready No
HD Radio No
Navigation ---
iPod Compatibility
Full size Classic/5Gen
Nano 7/6/5/4/3/2/1
Touch 5/4/3/2/1
iPhone 5S/5C/5/4S/4/3GS/3G/2G
General
CEA-2006 Compliant No
RMS Power Output 22 watts
Peak Output 50 watts
RMS Power Bandwidth 20-20kHz
Preamp Outputs 4-channel
Sub Preamp Outputs No
Switchable Rear Preamp Outputs Yes
Video Screen No
Preamp Voltage 2.5 volts
Display Color Variable
Key Button Color Variable
EQ Bands 3
Wireless Remote Yes
Steering Wheel Control Compatible Adapter required
Parts Warranty 1 Year
Labor Warranty 1 Year
Tuner
FM Sensitivity 8.2 dBf
European Tuning Yes
Seek/Scan Seek
Radio Data System Yes
Product Research
Oh god a Rockville. And JVC.
8v in 2.5v out. A hair over half gain will be close. I wouldn't even chance trying to get full power out of it. A bit to much and dirty dirty. Smoked speakers.
Oh god a Rockville. And JVC. 8v in 2.5v out. A hair over half gain will be close. I wouldn't even chance trying to get full power out of it. A bit to much and dirty dirty. Smoked speakers.
'Oh god a rockville'//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif haha. So a hair over half gain for set up and for the first few months then I can turn the gain a bit more?
Or anything a hair over half gain and its asta la vista set up?
No it don't work like that. If you have 2.5v preouts and you run the gain past 2.5v that's over driving the amplifier, dirty power, burnt coils, wasted money, frustration. It's got nothing to do with months. Once the gain is set it don't move unless to back it off.
So would I be right in saying My front speakers wont even be pushed that hard:
https://www.rockvilleaudio.com/rvl6kit/
Rockville RVL6KIT 6.5“ 800 Watt Pair of Component Speakers With Aluminum Cone/Silk Dome
Peak Power Rating: 400 Watts Each / 800 Watts per Pair
RMS Power Rating: 100 Watts Each / 200 Watts per Pair
6.5” Mid-Bass Aluminum Cone Drivers
1“ Ferro-Fluid Cooled Silk Soft Dome Tweeter
1.25” High Power Voice Coil
Magnet Weight: 15.3 Oz
Magnet dimensions: 100 x 50 x 15 mm
Stamped Steel Basket
Alloy Bullet Phase Plug
Butyl Rubber Surround
Structure Weight: 70 oz
Complete with Wire Mesh Grills & Installation Hardware
Includes Flush and Surface Tweeter Mounts
Frequency Response: 65-22,000 Hz
Sensitivity: 93dB @ 1w/1m SPL
System Impedance: 4 Ohm
Mounting Depth: 3“
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
neil4374
neil4374
los angles
youdoofus
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
