Door sound deadening
  • 2
you're in luck, i'm an acoustical engineer and i spend a lot of time helping spaces be quieter by increasing transmission loss of doors, windows, walls, etc.
the primary source of noise transfer through a door is under it. if it's not water-tight, it's letting a lot of sound through the gaps.
you want to add seals around the door and especially the bottom gap. weatherstripping foam can be used for the top and sides.
for the bottom, you can start with a draft-blocker bottom seal which is just two pieces of foam pipe insulation in a fabric sleeve so the foam is on both sides of the door bottom.
the hollow door itself can be addressed after you've sealed the top, bottom, and sides. from there, transmission loss is increased by adding mass that is decoupled from the door (decoupled with foams or fabrics). you'll need 100% coverage that meets up with the door seals.
adding sound absorption in the hallway will help reduce source noise levels. there are many ways to do this. my favorite is to get some fiberglass ceiling tiles and put them behind painted canvas. it's cheap and very effective.
I have a door draft/sweep thing and it seemed to help mildly.
Are there any specific fabrics, closed cell foams or door seals that work particularly well? Don't want to spend $$$ and get poor results.
If I made my draft blocker/door sweep more dense would it work better?
A roll of weather stripping foam should be $3 or so and you will need two rolls. Thickness should depend on how much of a gap you have. You want it to compress but not impede on operation of the door
You could replace the foam in the draft blocker with PVC that is covered in felt and stuffed with some sound absorption
Sent from my SM-G900V using Tapatalk
Water or moisture on any Electronics is never a good practice nor a great out come of operating correctly . If you want to keep that same unit, Id...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
381
Tons of options in that budget, including the cost of installation,
10
692
1980supreme
1980supreme
Canada
keep_hope_alive
Doxquzme
    May 8, 2024
DEW123
    May 7, 2024
Latest topics
