SS Rubicon 1.2500 and 4.500, Custom Painted
  • 5
Joebobclark
Your Moms New Boyfriend
Thinking of going a different route with my amps, so I throw these out there to see if anybody wants them!
Soundstream Rubicon 1.2500 and 4.500 (have 4.600 as well, not working, but can be added if wanted)
http://soundstream.com/store/rub1-2500d.html
Has 0ga power/ground, even though site says 4ga. (Toolmaker inputs NOT included, sorry)
RUB4.500
Custom painted (boards removed, heaksinks stirpped/primed) metalcast blue with black end caps, also replaced/upgraded fans in the 1.2500 while it was open (2 fan model) old ones were getting noisy..
1.2500 and 4.500 in excellent used condition. 4.500 has one tiny nick in the paint.
The 4.600 turns on and within a minute or so goes into protect, with no RCAs or speakers connected. Just started doing this past few days.
$450 shipped for both the 2500 and 500, will add the 4.600 for $25 more (just to cover shipping)
Would also trade for 2 PPI 900.4s
Included
Honestly, these particular amps aren't bad for the money.
Been running mine for over a year or so now and no problems. I did notice my big amp makes noise, as you stated, but goes away after a min or two. The noise is the fan(s) built in. I happen to have the 2 fan version amp. When the 2500.1 amps first came out, only 1 fan was used.
When you replaced the fans in the big amp, did it help out at all?
I swapped to ball bearing fans, so its a little quieter. And the new ones are slighter higher CFM (air movement) to help with cooling. I just did it because the original ones would make the noise for the first 30 secs or so at start up, being a bushing fan.
Hey joebob have u or would u know if the 2500 can drop below 1 ohm on stout electrical? Interested in all
It will run .5 ohm with good electrical and maybe a fan to keep it cooler, depending on where/how its installed...
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
968
Hello new to the forum. looking for some help from the guru’s out there. i have the factory alpine 10 speaker with the 8.4 uconnnect. im...
Joebobclark
Joebobclark
Milford, NH
Joebobclark
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
