Mounting diameter for Sundown X12
  • 1
Ok, I will use the OEM location and wiring. The 5.25's are lower door. Buick gave it some thought because there is a plastic inner panel with a...
4
46
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
5K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
moparerrnocar
moparerrnocar
Fargo, ND
moparerrnocar
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
