FS Orion HZ bass old school NIB never seen power carbon subs
  • 1
DallasOldSchool
Host to sales and advice
17
Dallas
These are über rare. I'd like $300 for the pair. Pm or post with questions.
This is txt from the spec sheet...
HZ 8 SPECIFICATION SHEET
You have purchased the finest car audio loudspeaker available.
HZ Bass Drivers set new standards for performance and reliability.
They are superbly crafted and precision calibrated.
If you install each loudspeaker properly, you will be astonished with the quality of sound and you will
have an audio system that you can be proud of and enjoy for many years.
HZ 8 SVC
Nominal Impedance……………………………………………4ohms
Re (DC resistance)…………………………………………...3.3ohms
Levc (coil inductance)………………………………………..0.29mH
SPLo (reference efficiency) @ 2.83v…………………….87.2dB
Fo (free air resonance)………………………………………..44.6Hz
Qms (mechanical Q)……………………………………………..…3.13
Qes (electrical Q)…………………………………………………….0.89
Qts (total Q)…………………………………………………………….0.69
BL (force factor)……………………………………………………5.5TM
Sc (cone area)…………………………………………….0.0206 sq M
Vas (volume acoustic suspension)…………………26.3 Liters
Vas (volume acoustic suspension)…………………..0.93 cu Ft
Xmax (excursion)………………………………………………..7.0 mm
Pmax (thermal power handling)…………………….300 watts
Mounting Diameter…………………………………………….7.75 in
Mounting Depth……………………………………………………4.0 in
Basket Displacement……………………………………...62.5 cu in
Voice Coil Diameter…………………………………………......1.5 in@%1;
View attachment 26542078View attachment 26542079View attachment 26542080
HZ 8 SVC
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
671
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
DallasOldSchool
DallasOldSchool
Dallas
DallasOldSchool
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
