JBL MS-62C 6.5" Components, 2 sets
  • 4
trumpet
Barry Schanz
JBL MS-62C
NIB
These are one of the hottest values in 6.5" components right now. Build quality on these is on par with $500+ sets from other brands. Even the manual stands out, with full color photos.
JBL® MS-62C at a glance:
  • 6-1/2-inch fiberglass laminate woofer cone with vented, cast-aluminum basket
  • Titanium inverted-dome tweeter
  • Separate woofer and tweeter modules with a high-quality external crossover
  • Woofer phase plug
  • Spring-loaded push terminals
  • Power handling, RMS 160W for the set (80W per side)
  • Frequency Response 60Hz - 20kHz
  • Nominal Impedance 4 ohms
$200 shipped
Free USPS Ground shipping within the Continental US
international shipping available
I can do a package deal with a Massive Audio BX2 2-channel amplifier or a Precision Power P900.4 4-channel amplifier, as well as an amplifier installation kit and extra RCAs. If you want coaxials for the rear I have JBL GTO628 and GTO8628 6.5s or 6x8s in stock.
how do these compare with Infinity perfect 6.1s
Without hearing either set it's a guess, but the two sets should be at a similar level for quality and output while having different characteristics. I believe the Kappa Perfect line was discontinued before the MS line from JBL was released, so MS-62C has the latest technology.
---------- Post added at 10:10 AM ---------- Previous post was at 10:09 AM ----------
any trades?
Cash
Cash
what an unusual medium of exchange.
also, are these under warranty?
My JBL/Infinity distributor is out of MS-62C until they can meet their minimum order. I ordered the P660C Power components to substitute and they will be in my hands tomorrow.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
906
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
Brendon Jenness
    May 8, 2024
    May 8, 2024
