Nvx?
I have been wondering the same about these
I just bought a 12 VCW, i will be pushing with a kicker 1200.1 i think, im in a single cab pickup,  i just blew a coil on my new l7 with the amp on a higher ranged bass song, still one good coil, i bought the amp with the truck and there use to be a older l7, like 07 i think. it did great but i did not get that sub, I looked up the specs for the new l7 12 and saw 750 watts and then knew why i blew it,  Hoping this 1000 watt rms will be more up to the parr for my amp.  I had a RdAudio sonance 12 that killed it with this amp but developed some noise, glue was failing. so i put it away before i break it because ❤️ that speaker.
The GP Audio Glue and screw it enclosures are fantastic and easy to put together with the cut sheet and everything is labeled. I use silicone to...
I'd rather have the volt meter on the knob personally
You should have no issues with NVX. They are one of those “good bang for the buck” companies.
I have a 2012 Chrysler 300 limited. I would like to do four NVX VCW124 12” subs in the trunk. My idea is to remove the arm rest from the rear seat...
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
THATpurpleKUSH
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
