woofersetc deal on CDT's & Amp?.. Any good?
Not a bad price at all. The cdt components are a couple of years older stock and don't have a cdt warranty I suspect the amp too but still a decent budget set up Might be ok
you can purchase CDT audio at a great discount from techronics.com, their prices are crazy low.
Techronics is not a CDT Audio dealer. Read the fine print. When they had CDT Audio product on eBay I believe they all said there is no factory warranty. It's no better than buying old stock from woofersetc.
There's a sweet arc 400.4 in the classifieds that is active capable. Buy that and a set of used comps... You will be stunned if you install it right. I have a set of cdts that are nearly identical to the ones in your link and a 120x4 active-capable highs amp (the gear in my sig) that was found for 130$. Total. And it sounds unreal for what I paid.
(NEW) Pioneer 9" DMH-T450EX Digital Multimedia Receiver with Weblink - $189.99 - Free shipping for Prime members...
The one you linked is still a bit iffy if you intend to push things. Consider the cells are rated 100A Max discharge which means if they're the...
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
What also helps is the suspensions on them aren’t as tight as a virgin on prom night! Sorry I couldn’t resist using this joke 🤣
33
Inocense
Inocense
Chicago, IL
av83
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
