best .5 ohm 2000 watt amp?
Crescendo bc2200 should run fine at .5 on good electrical. It's $329 on the SSA store and there is an optional .5 ohm extended warranty.
Dumb noobs didn't mention the mmats 2000.05... Rated at half ohm does rated power over 13v easy on electrical and very efficient
Refer to my post //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
592
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
902
garretttt4
big pimpin
garretttt4
Watertown sd
    Apr 26, 2024
    Apr 26, 2024
