RockfordFosgate repair service
  • 1
elite08
www.SoundAdviceTexas.com
I have a blown t1000bd amp, the speaker wire is melted in the channels and it's blown from the positive and negitive speaker wires touching. I was wondering if Rockford would allow me to send it in and have it repaired, the amps a monster and I really would like to be able to use it again. Also if it's possible, could you hook me up with the phone number to whom I would need to speak with at Rockford to get it serviced. Thanks guys
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
I was tempted to send an offer, but felt the 100 was fair for it since it was like new still. You still did good on it though.
elite08
elite08
Houston, TX ( Alvin ) [281]
elite08
    Jun 3, 2024
