What kind of electrical for around 7000 watts rms?
I am going to be running 2 ap30001d amps and 1 mb quart 800 watt
Holy ****...
How long do you plan on running it for? Vehicle on or off? I'd get 1 or 2 High-Output alternators, 200A-300A each; that'll supply about 4400W- 6600W. From there you're gonna need an enormous bank of batteries. You'll also need probably 3-4 runs of 1/0AWG.
http://www.knukonceptz.com/productDetail.cfm?prodID=KFX0BL
Any more info on equipment?
not really. u can run it off one good ho alt, and about 400 ah worth of batteries. you don't need a HUGE bank of batts, just a couple decent batts, lots of good, big wire, and a ho alt.
There's a difference between being able to run a system, and being able to run it well. I prefer the latter.
250a
4 C&Ds
1 good upfront batt
4 1/0s
thats my plan for 8K+
we'll see if more is needed //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Holy ****...
How long do you plan on running it for? Vehicle on or off? I'd get AT LEAST 2 High-Output alternators, 200A-300A; that'll supply about 4400W- 6600W. From there you're gonna need an enormous bank of batteries. You'll also need probably 3-4 runs of 1/0AWG.
i know over kill is very good when it comes to electrical but you cant be serious! hell just 1 HO 300 amp alt with an decent batt will supply over 4kwrms jesus!
he didnt say 17kwrms!
He gave us very little information. I always design electrical systems with extreme pessimism. I assume that everything will be inefficient, and will be playing for long periods of time. I know it's not necessary, but vague questions often get misinterpreted results.
AT LEAST 2 HO Alts that are 300a?
thats a bit overkill lol.
Lawl. Didn't mean to put at least there. I'll edit that //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Update: The burning smell is slowly going away at middle volumes. To the point where it only comes on at middle volumes. I adjusted the sub master...
17
mgcauctions09
mgcauctions09
alabama
loudmofo
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
