2006 Grand cherokee... HELP!!!!!!!!!!!
  • 4
if it needed a code it would still turn on and would just be locked out. Is there also a fuse under the hood for the radio? I had an 07 but never had any problems with the stock radio when removing and replacing it.
has anyone had a problem with the factory radio not turning on? i took out the remote wire and crimped the originals back together and still nothing..
when i turn the key to acc, i hear a faint speaker pop and then a little really(and i mean really) faint whine then it stops after like 10 seconds
any and all help is greatly appreciated!
I guess you don't have a owners manual laying around? The fuse box may also have a diagram on the inside of the cover.
it does but the one i replaced did nothing and i was asking about an internal h/u fuse, but sorry for not being clear
fuse #28 (20A) is the only fuse for the radio
next, check both red/ orange stripe wires for b+ and both the solid black wires for ground in the bigger stock head unit connector
Those cars use a CAN system and there shouldn't be any 12V source at the headunit...MAYBE constant. SO my guess is you blew a fuse related to the ECU or something similar.
We are selling one of our new cars because our needs are changing; one of us will be driving much less. I have a 2006 Honda Element that’s been...
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
5K
Blinkrazy
Secretary of the Internet
Blinkrazy
Macon, GA
qkassidyw
audiobaun
    Apr 27, 2024
audiobaun
    Apr 27, 2024
