Box Build for matador_de_sa
the727kid
St. Pete, FL
Build is for 2 10" Kicker CVXs. Box is 3 cubes with 42.5" of port tuned to 34hz. Box will be carpeted and painted port.
Once again... 16x48 sheets FTMFW
All cut
Sides Up
Best Technique IMO to carpet
Front On
I left off here, will finish it tommorow hopefully.
looks good
and btw in your sig you put sundwon, not sundown //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
looks good....i see a little fisher carpeting type action going on there. Just need to perfect that bottom seam
Yea I'm still trying to figure out how to perfect that. I know the technique, it just never comes out 100%.
i glue the seam down to the bottom when i first start the carpeting process....then when i get the second seam all the way around the box, i overlap the 2 seams. Using a straight edge, i cut through both layers, then peel up the thin strip that was was glued down, spray on some more glue and the seams line up perfect from there. I don't even touch the sides until that bottom seam is 100% perfect
i imagine it was either a rabbitting bit or a straight cut bit in a router
Good guess....
But it really only works well with a router table, which I don't have.... So I lower the blade on the table saw to about 1/8th" and then I set the guide to an 1/8" and use that, works much better than the router.
Looking good, very nice build and good job on the carpet.
Where did you buy the carpet from? and what did you use to glue it down?
966
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
the727kid
the727kid
St. Pete, FL
bigbangtheory
Brendon Jenness
    May 8, 2024
    May 8, 2024
