Running 4 speakers off 2ch amp
  • 2
Naxis2k1
grade A whiteboy
598
Phoenix
Is this a bad Idea? If you wired everything parallel could it work or are the some unforeseen problems with doing this? Wouldn't this still present a 4ohm load and be deemed acceptable
EX:
4ohm + 4ohm ------>(in parallel)to ch1
4ohm + 4ohm ------>(in parallel)to ch2
If your running two 4 ohms in parallel then you would result in 2ohms. Make sure your amp is 2ohm stable and supplying the correct power at 2ohms. Too much and it could blow your speakers.
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
399
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
Warren G
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
