alternative place to connect horn output
Colt9699
Rockstar
1,977
Erie Pa
I have the wiring diagram for my vehicle and i know which wire to hook it too, just cant find the **** wire.
is there another place to connect the horn wire other than in my steering colum?
I even looked for the horn under the hood and cant find it........figured i could dmm it and figure the - line and connect it there.
any help would be great.
I would find the horn under the fount of the car and just connect it at the source, or at least take a good look at it and then try to match it up with one under the steering column.
What are you trying to do, might be of more help if we knew.
1999 Mercury Villager
I am just trying to get the horn to honk when I arm the unit.
All i have now is the light flash.
Its Crimestopper unit
You misunderstand me, Its not that I cant find the right wire, I cant find any of the wires.
This steering coloum is the weirdest one I have ever seen and there is not wire running thru that I can see no rubber grommet or boot that i see either.
Any way you can post pics? If you cant find any wires, you may have to take the bottom of the steering column off and find the ignition switch and follow the wires from there.
X2 i was just gonna type that. gotta pull the shroud off and look for them. the wires have to be there exposed otherwise they wouldnt tell you to grab them there. try to post a few pics of it. or you can just get a siren and use that.
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
4
Hey there I've had this Axxera AV7336MB for years now, but it's got some issues and needs to be replaced. I went to go buy a new one, only to...
Have you browsed the Audio Control DSPs, like the DM608?
I love my m25 tweeters and will likely try the tm65mkiv or tm8 next.
8
3K
Colt9699
Rockstar
Colt9699
Erie Pa
THUNDERBIRD
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
