Running Tweeter on passive crossover without woofer??
EEEK
I could be wrong on this, but if you don't have both speakers hooked up to a passive crossover, doesn't that do funky things to the OHM load the amp sees? I think I read that in one of the tutorials that came with WinISD, but I could be very wrong
this is what I read in the WinISD tutorial, not sure it applies to you though
Notice that in each branch, the inductors and capacitors are in SERIES with each other (L1 is in series with C1, and C2 is in series with L2). In each branch, the inductor and capacitor are each chosen so as to offer 8 ohms of reactance at 1500 Hz. What this means is that at 1500 Hz, the cap is offering 8 ohms of capacitive reactance, and the inductor is offering 8 ohms of inductive reactance. Capacitive reactance and Inductive reactance are exact opposites, and cancel each other out! If you have 23 ohms of capacitive reactance, and 18 ohms of inductive reactance in a circuit, the net reactance is 5 ohms (the difference of the two). If the woofer or tweeter are removed from the circuit (become unplugged, or electrically "open" during play), then what you have is 8 ohms of capacitive reactance, and 8 ohms of inductive reactance in that branch. Since the two reactances cancel each other out, then the amplifier effectively sees a grand total of ZERO ohms at 1500 Hz! This will result in a damaged amp. Keep this in mind when considering implementing a 12 dB/Octave passive crossover into your system. Amps with built in short circuit protection will most likely survive this scenario, however...
Oh snap!
In this case though i think the resistance would double would it not? Only one path for the electric current instead of two (tweet and woofer)
I think its a good idea just to wait till you get your mid back
I have some 6.5" mids in my doors that are only playing from 80hz-250hz. I think I'll just hook the one up to the crossover for the time being until I get the 5.25" MB Quart back. I'm sure I will notice a midbass speaker missing far less then a main one for the components in my kicks. It will be kind of ghetto but probably the best idea for the time being.
EEEKI could be wrong on this, but if you don't have both speakers hooked up to a passive crossover, doesn't that do funky things to the OHM load the amp sees? I think I read that in one of the tutorials that came with WinISD, but I could be very wrong
This can definitely happen.
What happens, to paraphrase the WINISD manual, is that without the woofer inline to "damp" the crossover, the coil and cap in the woofer crossover will resonate at the crossover frequency, and will SHORT the amp at that frequency. Many amps will go into overload from this... spitty, harsh sound, and sometimes, even "whistle tones"... ie, OSCILLATION.
I've HEARD this happen, in a very few cases. In at least one of those, the amp was SMOKING before we could turn it off...
If you're going to do this, get a VERY HIGH POWER resistor (4 to 5 ohms, at least 50 watts... you could parallel 2- 8 ohm 25 watt resistors) and put IN PLACE of the blown woofer. That way, the crossover sees an appropriate load...
Regards,
Gordon.
I put my midbass speaker on it and it's much better. The tweeter was making some weird sounds and now it stopped. I guess this will be okay for now. It's just weird having sound coming from a kickpanel on one side and the door on the other.
Christ...just get a DMM and measure the resistance if you're so worried. If you double the resistance (6 ohms to 12 ohms) the power is halved.
We're talking impedance not resistance. Impedance is frequency dependant, resistance isn't. Whatever you measure with the DMM won't matter for squat once you apply an AC voltage to the circuit.
I don't know about other speaker sets, but my Germanium's manual says you will fry your **** if you try to push power through your x-over with only a tweeter or only a woofer connected. It states to "NEVER APPLY POWER TO YOUR GERMANIUM CROSSOVERS WITHOUT CONNECTING BOTH LOUDSPEAKERS FIRST" or something very close. Maybe other company's x-overs/speakers work differently; i'd call them and ask.
IIRC it's only a problem with 2nd order crossovers. I may be wrong, but I have that in my head for some reason and I'm too lazy right now to actually put forth the effort to research it at this moment.
But, the moral of the story is that it is possible to damage your equipment by leaving one of the outputs on the crossover "open"
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
338
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
badstang123
badstang123
Los Angeles, CA
squeak9798
    Apr 26, 2024
    Apr 26, 2024
