ZED Audio Leviathan??
ok run that crescendo amp at 2 ohm on the front 2 channels and u will put out 250rms between the 2 speakers, with the channels 3 and 4 running at 4 ohm each giving ur backs 125 each, that will be plenty, their is no need to have more power. if i was u that is what i would do
is that a good amp?
ok but i have 6 speakers..lol u run run all the door speakers to 2 channels....at 2 ohms each channel...the run my dash at 4 ohms at the other two channels?
Every post I see of yours, you're telling people to go grab a Crescendo amp. Are you a dealer? Do you honestly think that Crescendo amp even holds a candle to the Leviathan?
I wouldn't run Zed just because of the way he likes to treat the "little guy". Well that and the cult like following that he seems to have where someone merely mentions the name Zed and a circle jerk, stroke-a-thon ensues. I went down that road with Linear Power and I'll be dаmned if I am making that mistake again.
tell me when i have recomended a crescend now ur talking out ur ***. navid is the owner. and no im not a dealer im a professor at college who leaves near crescendo in florida and have used their products. they come from the same build house as sundown so yes their quality amps.
id second linear power over zed. but zed does make a quality product, u can run the amp at full range but u might hit 2 low of notes as u wont have a high pass crossover. get distortion
yeah what ryan said..i didnt know if ure head unit had crossovers...but if it does go for it...flat and use hu
ok man thanks...so it would sound as good as any other amp right?? the whole flat part makes me think the sound coming from the speakers would be flat...and i sure dont want that...lol
if your going for quality you want the flattest response possible. the "flat" setting is just a way of saying the amp will be reproducing the full spectrum of frequencies available. just like high pass means it lets frequencies higher than the crossover point will pass to the speakers "HIGH PASS" and vice versa for the low pass setting. LOL
thank you for explaining that thats what "flat" means.....ol makes me fel a lot better...i beleive i am gonna purchase this amp tomorrow then i will be selling my 100.4...haha so i can leave my settings on my amp set to flat and then set my headunit to 100hz an not have to mess with anything else and i can use all 6 channels?? good good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif exactly what i wanted to do...now i dont have to have two seperate amps for my highs.
treylittlefield
treylittlefield
Sand Rock, AL
treylittlefield
