ZED Audio Leviathan??
I wouldn't run more than 4 sets: 2 sets on channels 1&2 and 3&4. channel 5&6 only have a low pass filter so it wouldn't work for another 2 pair of comps
so i just talked to stephen from ZED...and he said that i could run all 6 channels on flat and it would work...how do you guys think that would work? idk exactly how "flat" would sound..
you said u were running 6 sets of componentS? well id put all the
tweeters on channels one and 2
and the mid range on three and 4
and if u have a midbass you can run it on 5 and 6
or if u dont have a midbass...run half the mids on 3 and 4
and run the other on 5 and 6...to get some decent low end
you said u were running 6 sets of componentS? well id put all thetweeters on channels one and 2
well all the comps have crossovers....so i would hook one crossover to each channel...meaning there would be one mid and one tweeter for each channel..lol does that make sense?? lol
i figured it would be easier to run these passive..i have two comps in each door..and one set in the dash
yeah i get what u mean...well i was suggesting you rid the crossovers and hook all the tweets together...all the mids together....and set the filters on the amp...or since im guessing u have comps in the rear
you can...
do option a which i stated...or do
4 tweets on channel 1 and 2
4 mids on 3 and 4
and run one set each to 5 and 6...
but option a is the best...or what i would do
oh i see...well i think my option is a good one but lets see what others have to say. do u know what components your using?
yes my dash speakers are 4inch componets from CDT...they are the higher end ones..
the door speakers are 6.5 CDT's...i believe they are the entry level comps..
the dash needs 150 rms i believe and the doors need 100rms...so i was just gonna run each component to each channel to save the trouble of tuning..and then maybe later run it active if i ever get the want to do it
ok run that crescendo amp at 2 ohm on the front 2 channels and u will put out 250rms between the 2 speakers, with the channels 3 and 4 running at 4 ohm each giving ur backs 125 each, that will be plenty, their is no need to have more power. if i was u that is what i would do
treylittlefield
treylittlefield
Sand Rock, AL
treylittlefield
vegang
vegang
