Z71 extended cab
camaroaudio69
B@ngin Loud
Well i sold the camaro and gotthis now so im switchin up the system. Im pretty much set amp wise with the sundown 1000d now its just the subs. Im going to either run two 12s or 4 10s I basically can spend up to around 400-450 for subs im looking for a good daily driving system that gets pretty low. Just wanted to see some ideas on subs. Right now i was thinking about L7s CVxs or some dc level 2s any other ideas?
its not possible with the seat in there. even if you raise the seat 2-3 inches, you still wont get them the proper air space. well depending on what subs but it will still be hard. im working on a design for my 06 silverado right now
The seat has not been raised
The bottom of those seats have no structure under them only loose hanging carpet (you can make the height of the box lower if needed
Don’t remember the volume at the moment (plenty of room), however I only build boxes that work
No offense but that looks pretty bad with the box protruding out that far from under the seat...you must never have any passengers back there? Not to mention it doesn't look like the seat goes all the way down to it's locking position.
I never have passengers and the seat has since settled down a bit....All in the name of BUMP
camaroaudio69
B@ngin Loud
camaroaudio69
dowtown near tha lake
blackbonnie
