Yet another Help Buying Amp ?
atvguy585
6
AZ
Well I love music and listen to it everywhere and decided my stock speakers just don't cut it anymore. I put in a sub and double din dvd head unit 2 years ago and never got around to upgrading speakers. I ordered a set of coaxial speakers for the back and a set of components for the front, I will list the specs below. I need a little help deciding what a good 4ch amp would be to push my speakers. My ideal budget for the amp is $200 and under. I'm unsure what brands are good and which ones I should stay away from. I know for a fact pyle, boss, power acoustic all have poor quality from experience, unless I was lucky and got all crap units. This was the amp I was thinking about buying, what do you think? If you can offer me any other choices, I would appreciate it.
Front Component speakers:
Polk Audio DB6501
Overall Frequency Response 35Hz-23kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 125 w
Power Handling (peak) 250 w
Efficiency 92 dB
Rear Coaxial Speakers:
DB651S
Overall Frequency Response 50Hz-22kHz
Power Handling (continuous) 55 w
Power Handling (peak) 165 w
Efficiency 92 dB
The specs on that amp aren't very good....
THD at Rated RMS Power 1%
Signal to Noise Ratio 88 dB
Input Voltage 14.4v
If you're on a budget, I would go for something like the MB Quart ONX4.125. If you want a better amp, go Sundown.
Input Voltage 14.4v
Okay I will look around. I might go for better depending on how much more money were talking. Thanks for the help though.
where exactly did crutchfield get those specs? i downlaoded the manual and it doesnt give thd or test voltage anywhere. LOL. did they make it up??
Thank You for looking, I didn't even get a chance to look at the manual. Lol maybe they did. Well, I will do some looking around at the above brands listed as well as any other peoples' suggestions.
I just got it today!! It's really nice and the best part, the amp was tested by a person with a name. Most electronics come verified from the factory, tested by someone with a number. That leads me to believe that the quality will be great since they are not massed produced.
atvguy585
atvguy585
AZ
atvguy585
vegang
vegang
