Yet Another Box Building Thread
_i0n_
I'm trying to figure this out on my own..forgive me for my misunderstandings.
Respectively, these are my dimensions I've come up with..they are loose, I am just trying to match my Qts accurately.
H=14
W=16
D2=4
D1=10
This is a wedge shaped-sealedbox. D2 obviously being the top depth dimension.
These measurements yield 0.58 cu ft .. which I know is a tad large, but I am compensating for some bracing. Probably going to rip the 3/4 MDF down to 1/2"(as I have a lot of stock to waste) and brace all the seams.
Sub Specifications:
Fs: 25 Hz • Magnet weight: 150 oz. • SPL: 86 dB 1W/1m • Vas: 3.00 cu. ft. • Qms: 3.12 • Qes: 0.58 • Qts: 0.49 • Xmax: 14.3 mm • Dimensions: Overall diameter: 12-3/8", Cutout diameter: 11-1/8", Depth: 5-3/8"
Link:
Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm High Fidelity Reference Series 295-464
Thanks in Advanced for anyone taking the time to assist me.
What you have is a trapezoid to figure volume for a trapezoid:
First convert all your values to feet by dividing by 12.
volume = L * (b1 + (b2 - b1) * h1 / h + b1) * h1 / 2
In your case here are the values converted:
L= 16 = 1.334
h=14 = 1.167
h1=7 = .583
b1=4 =.333
b2=10 = .833
Google "calculate volume of a trapezoid" enter the values and you get:
.36 cu ft.
Your Vas: 3.00 cu. ft.
This is the size you want your box volume to be
Vas = Volume Air Space
at either .36 or .58 cu. ft. it is to small
I found this site very helpful:
http://www.bcae1.com/spboxnew2.htm
Your dimensions need to be more like
H = 18"
L = 24"
D1 = 8"
D2 = 16"
Were talking a 12" sub here not a 6-1/2" woofer
which is the original dimensions you give for.
_i0n_
_i0n_
Hell
RealAlan
