YESH! Not broken or ne thing
Yeah my car is a facking huge a$$ fatty 9x24. My buddies 12 sound hella loud in his car, but hes got a trunk that sits kind of high, and mine sits low, and is deep. I would like to strap another amp on there and get better subs one day, but that will a b long time coming, after i fix her up a bit, an worry about my front stage.
Running my kicker 1250.1 to them on one ohm, the 15's are capable of about 500rms each prolly a lil more, so its a good match. I have the HC1400 Kinetik in the trunk, 0 gauge wire all over for almost everything, one of the big 3 done, finish the rest soon. My speakers in the car are still stock, work with me here, im in college and working, so its not like its been quick to get this done. I had those subs for months b4 i even got the amp to go w/ them, and i had the amp at least a month and a half b4 i got the wire, and by then i had saved up quite a bit to get the battery at last lol.
They sound nice, def not great sq subs, but they hit pretty hard.
I'm happy w/ the results, mainly bekase I'm still learning, and this is the loudest i've seen subs in my area. I mean im sure ppl around here could blow mine away, but between me n my crew i run this so far.
Btw, i eventually need a diff box, its def not enough volume for the subs.
But thanks 4 lookin whether u found it amazing or not.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I think your substage is still pretty nice, is the box a prefab? That could be the reason why they're not hittin' so hard. I still have stock speakers in my Grand Am, but it still gets loud. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yeah, its prefab....
Its just now getting tolerable outside, so buidling my own wont b as hard, and now that I have it at least hooked up, i have some patience to save.
I do think its the box tho, it sounds loud, but im pretty sure they could b alot louder.
Its an inertia switch. It stops the fuel pump. Its so if you are in a wreck the car stops pumping fuel to reduce the risk of a fire
//content.invisioncic.com/y282845/emoticons/handclap.gif.0c301076f534e244f0460706894f19e0.gif for knowledge. someone on here actually knows about that kindof stuff.
KickerSoItBump
Thumpin Through
KickerSoItBump
Michigan
billabongcr
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
