XXX powering
From an 1800DT I wouldn't get my hopes up for 1,600watts. With that amp, you can consider yourself very lucky if you can get 1.2kw of clean power out of it.
As far as 1600 watts @ 4 Ohms vs 1600 watts @ 1 Ohm... typically, it is cheaper to buy an amp that puts out that kind of power in a low impedance load... a DVC 2 ohm sub like the XXX can present a 1 ohm load and allow a 1 ohm stable amp to 'give it everything it's got' so you are really going to be using the amp at 1 ohm, where as typically at 4 ohms (on a mono amp, at least) you are not running the amp that hard... if that makes ANY sense.
Think I got it. The sub doesn't know the diff. but the amp works harder at 1ohm than 4ohm.
Sooo... what amp would give me a clean 1600 watts to the XXX,
Dual 2 Ohm, quad 1.4, dual .7 available
I know the dual 2 can only go to 1ohm or 4ohm. do the others give me a chance to wire 2ohm.
Even if that amp put out 1800watts like it says or even more for that matter, I wouldn't worry about blowing the XXX unless you have the gains WAY WAY up. I run 2200-2400watts to my XXX daily which it handles no problem. Most people will tell you 1500-1800watts will push it enough, which is true. I just like it a bit louder //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can pay $15 extra and have the XXX made in a DVC 4ohm configuration, which give you the ability to wire parallel to a 2ohm load.
Check out these amps:
Hifonics Brutus 1500bd
Rockford 1501
Phoenix Gold Octane R30
Phoenix Gold Tantrum 1200.1
Resonant 36.1 (I personally would go with this)
I agree, if you can wait a little, I think the RE 36.1 will be a phenominal amp, if it is anything like the 35.1
Most of those amps are in the 1000w amps stick at the top of the Amplifiers forum
When is the RE36.1 due out. I don't have the money right now any way.
http://www.reaudio.com for the Resonant Engineering 36.1
It's not on the page yet, but they have contact information on the page. You can email or call, they've always been very helpfull for me.
As for the Hifonics Brutus:
http://www.sounddomain.com/sku/HIFBX1500D
and I would go to http://www.ikesound.com and pricematch w/sounddomain. This would get you the amp for $315 authorized...
The Tantrum 1200.1 is on http://www.sounddomain.com on sale for $380, which is a solid price..
The RF1501 is also on http://www.sounddomain.com, and I would also price match using http://www.ikesound.com.
It's best to go through an authorized dealer, if anything happens with your product you'll have a much better warranty. This is why I'd pricematch with sounddomain (authorized dealer), rather than directly going through http://www.ikesound.com (unauthorized).
As for the Hifonics Brutus:http://www.sounddomain.com/sku/HIFBX1500D
I just ordered this amp tonight, total was $312 shipped (from sounddomain //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif)!?!?! I have no doubts it will live up to what people have said about it here.
Tsunami db1800d If I get it in 2 ohm how would this amp be.
How much does the THD % mean to a sub amp cause the Brutus is like .08% and the Tsunami is at .5%
read my sig on the XXX. the mmats 1400.1 pushes about 1700 watts and this sub eats it up like its nothing. i can get this amp for $550 from a dealer friend if interested. retail is $899. whatever you get i wouldnt go any LOWER in wattage than what i have. i need more power and will probally be getting a 2200.1 soon! peace
smokeoff
here's my 3 cents
smokeoff
Cambria,WI
lexus rx
NorthFramingham
    Jun 30, 2026
