xtant 1001 ohm load question
bobbybdemented
I'm wiring two dual 4ohm subwoofers to a xtant 1001x my question is if I could wire each sub to 2 ohms and hook them up to the terminal and it would be a 2 ohm load? The terminal has two channels that looks like this +-+- or should I just run them parella at 1 ohm?? I would rather have a 2 ohm load.. and what is this amp rated at 14.4 volts cause I hooked it up to two kicker solo classics at 2 ohms and it fried them in 3 days.. the kickers are rated at 600rms and they burned the f up!
that is a 1 channel amp with a speaker terminals to fit 4 wires..if your wires will fit in just one hot and one ground speaker terminal use it like that...if not use the other 2...
but, make sure to wire your subs to 2 ohms . don't wire it to 1 ohm. im pretty sure it wont like it...
bobbybdemented
bobbybdemented
houston
bobbybdemented
