I'm looking for a pager alarm, double din dvd player/screen, TC-3000 15 and maybe a few other things, so let me know what you have. I have a ton of stuff laying around that I don't need and I'm hoping to trade it for something I can use. Maybe I'll throw in some cash if I'm really interested but the holidays have kind of drained me of that. Everything is for sell, please pm me for anything you may be interested in. Thanks
MTX Thunder 502 2ch. amp
Amplifier Type Dual Channel
Bridgable Bridgable
RMS Power at 4 Ohms 90 W x 2
RMS Power at 2 Ohms 180 W x 2
Performance
Frequency Response 20 Hz - 20000 Hz
Signal to Noise Ratio 110 dB
THD at Rated RMS Power 0.1 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 40 Hz
Low - Pass Frequency 40 Hz - 200 Hz
High - Pass Frequency 40 Hz - 200 Hz
Other Features
Input Voltage 12.5 volt
MOSFET Circuitry Yes
Dimensions
Width 12.6 in.
Depth 9.75 in.
Height 2.1 in.
Boston Acoustic S60 Components (no grills)
Nominal Size
6-1/2" (165mm)
RMS Power Handling - 55w
Peak Power Handling - 150w
Frequency Response (±3dB)
58Hz-20kHz
Impedance - 4ohm
Sensitivity (1 watt (2.83v) at 1m) - 92dB
Mounting Depth - 2-1/2"
Prefab Dual 12" Sealed Enclosure (local pickup only)
Custom box for 3 12's common chambered and double baffled (local pickup only)
3 MB Quart RWE-304 12's
4ch. Power Acoustik amp A600-4HP (matches mono DB series amps)
RMS Power Output: 85 Watts x 4 @ 2 Ohms
Birdged Output: 600 Watts
Signal To Noise Ratio: 97 dB
Frequency Response: 10-30,000 Hz
Bass Boost: 0-18 dB
Built-In Crossovers: HP / LP
THD @ 4 Ohm RMS Power: 0.02 %
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 11.25 L x 11 W x 2.3 H
Phillips Hard drive DVD Recorder/Player model: DVDR3400 BNIB only tooken out to test it.
Emachines D2880 Desktop Computer and I added a 512mb stick of memory
LG external DVD burner
17" NEC LCD monitor (black and grey)
Logitech Z-4 2.1-Channel Speaker System
Custom black felt pool table 8' x 4' custom built (obviously local pickup only)
Like new LG 160W Compact DVD Shelf System with USB Port
Model: LFU850
Gamecube games: Geist, Sims Bustin' Out, NBA 2k2, Madden 2004
Computer games- Lands of Lore Guardian of Destiny, Battlefield 1942, Medieval Total War, Iwo Jima, Morrowind The Elder Scrolls III Game of The Year Edition
Nice Corona Neon Bar Sign (REAL bar neon sign)
Kenneth Cole watch
Bridgable Bridgable
Performance
Other Features
Dimensions
Width 12.6 in.
Depth 9.75 in.
Height 2.1 in.
Nominal Size
6-1/2" (165mm)
58Hz-20kHz
Impedance - 4ohm
Bass Boost: 0-18 dB
Low Level Input: No
Model: LFU850
Kenneth Cole watch
