I have a Sonic FX Q 12" D2 that I have no need for, It is a TC-9 based motor..Very Identical to the first gen IA DP.. I would like to trade it for a battery..maybe something around a kinetik 1400 or bigger...I can add cash if needed...
specs
Driver: 12 Inch: 15 Inch:
Fs: 33.5 Hz 32.8 Hz
Re: 4 ohm series 4 ohm series
Qms: 5.400 4.963
Qes: 0.362 0.371
Qts: 0.339 0.345
Mms: 171.548 g 299.846 g
Cms: 126.846 74.996
Sd: 0.048 0.080
Vas: 41.501 L 68.125 L
Spl: 91.8 db 1w/1m 92.8 db 1w/1m
BL: 18.990 TM 26.591 TM
X-max: 38 mm peak to peak 38 mm peak to peak
Sub diameter: 12 5/8 inches 15 3/4 inches
Mounting: 11 1/8 inches 14 1/8 inches
Mounting depth: 6 5/8 inches 7 3/4 inches
Driver displacement: .22 cubic ft. .22 cubic ft.
Power : 2000rms / 2000rms
specs
Fs: 33.5 Hz 32.8 Hz
Qms: 5.400 4.963
Qes: 0.362 0.371
Qts: 0.339 0.345
Cms: 126.846 74.996
Sd: 0.048 0.080
