WTT RD Audio 5750.1
revots
Mata de Leo
Looking for a SAZ 1500, RD 1750.1, 20.1, etc... and a 2 or 4 chan.
Amp is a beast, 33lbs of sexiness.
specs:
* Digital class-D linkable mono block amplifier
* MOSFET PWM power supply
* Daisy-chain through output RCA
* Heavy duty cooper layer double sided epoxy PCB
* Stable into 1 ohm and 2 ohm parallel amplifier connection availability
* 24 dB low pass (LPF) crossover variable
* 18 dB bass boost equalization control variable
* 180 degree variable adjustable phase shift
* 24 dB subsonic filter variable
* Selectable Switch for MASTER and SLAVE Operation
* Speaker short, over current, thermal, and DC protection circuit
* RCA line input and line output
* 2 x 0 guage (AWG) battery input connectors
* Efficiency: 86% at 4 ohm, 100 Hz
* Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
* Operating voltage: DC 10V ~ 18V power input
* Damping factor: better 350 into 1 ohm
* Wired remote controller
MSRP
$2199.00
Specifications
RMS power, 2 ohm linkable/dual mono 9000w x 1ch
RMS power, 1 ohm mono 5500w x 1ch
RMS power, 2 ohm mono 3200w x 1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 620(L)
and?//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
how do you like the 1500?
I love it. I've got a blowthrough on my mind right now so I'm going to be needing more power.
revots
Mata de Leo
revots
newport news, va
revots
