I have a 6.5 componet set and a 4ch amp and both are brand new i also have a used Audiocontrol 2XS and 3XS iam looking for 1 or 2 good SPL 12in subs iam willing to put up cash along with trades....
below are products and spec
BNIB Blaupunkt VA4100 AMP MSRP$449.99 here are the specs:
4/3/2 Channel amp
700 watts MAX, Class A/B Velocity Series 4-Channel Amplifier
RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
4 ohms Bridged: 300 watts x 2 chan.
MOSFET Power Supply
CEA-2006 Compliant
Short Circuit Protection and High, Low, Reverse Voltage Protection
ThermalThrottle Full-on Power Assurance
RCA Type Input/Output
Frequency Response: 15 - 50,000 Hz
Remote Gain Control, Screws, and Mounting Hardware Included
12 dB per Octave, High Pass and Low Pass Crossover
Dimensions: 15.1"L x 9.1"W x 2.4"H
http://i73.photobucket.com/albums/i2...incojr/amp.jpg
http://i73.photobucket.com/albums/i2...ojr/ampbox.jpg
http://i73.photobucket.com/albums/i2...ertificate.jpg
BNIB Blaupunkt VC650 componet set MSRP$189.99
Velocity Series 6-1/2" 2-way Component System
3" voice coil and huge magnet for extreme power handling
Woven fiber cone
Rugged cast aluminum basket with rubber surrounds
Surface and flush mounting caps
Polypropylene magnet caps for improved protection and appearance
Multi-hole mounting
Power Handling:
120 watts RMS
240 watts Peak
Frequency Response: 65 Hz - 23 kHz
Sensitivity: 91 dB
Magnet Weight: 11.3 oz.
Mounting Depth: 2.8 in.
http://i73.photobucket.com/albums/i2...peakerbox2.jpg
http://i73.photobucket.com/albums/i2...peakerbox1.jpg
http://i73.photobucket.com/albums/i2...omponetset.jpg
http://i73.photobucket.com/albums/i2...ecincojr/6.jpg
http://i73.photobucket.com/albums/i2...r/SA400088.jpg
and last but not least i have a used AUDIOCONTROL 2XS 2-way Electronic Crossover and an older 3XS
State-Variable, 18dB per Octave, 2-way Active Crossover
Module Programmable Crossover Frequency
Balanced Inputs
Output Level Controls
Switchable Isolation PWM Power Supply
on looks i give it a 5
but it is fully functional and works great
http://i73.photobucket.com/albums/i2...incojr/2xs.jpg
4/3/2 Channel amp
RMS Power Rating:
MOSFET Power Supply
CEA-2006 Compliant
Woven fiber cone
Multi-hole mounting
Power Handling:
120 watts RMS
240 watts Peak
Sensitivity: 91 dB
Balanced Inputs
