Inter007
Looking to trade my DD M1a for a pair of 12's, pair or possibly single depending on sub 15(s) or 18(s). Can be either D1's or D2's. Have 2 of these amps so just looking to get rid of one so i can have a bit of bump on a second car. Space is not really a problem since it will be put in a a suburban. Offer up. ***No blown subs please*** Got this amp from @dbass earlier this year. Only used it once since to test a subwoorfer was working properly and havent used it since
***Specs i got from an old post on this forum for same amp***
---1 ohm - 1200 RMS
---4 ohm - 300 RMS
---Dynamic Power
---2300W x 1ch
---Input Sensitivity
0.2V - 8V
---Variable High Pass Filter
--- Subsonic Filter
10 Hz - 50 Hz at 24 dB/Oct
---Variable Low Pass Filter
20 Hz - 200 Hz at 24dB/Oct
---Clipping Display
LED
---Tested Voltage
14.4V
---Tested THD
1%
---Efficiency thru Output
>75%
---Dimensions - mm
300 L x 235 W x 53.4 H
---Dimensions - inches
11.81 L x 9.25 W x 2.1 H
---Signal to Noise
85 dB
---Shipping Weight
12 lbs
View attachment 26540660View attachment 26540659View attachment 26540658View attachment 26540661
---1 ohm - 1200 RMS
---4 ohm - 300 RMS
---Dynamic Power
---2300W x 1ch
0.2V - 8V
--- Subsonic Filter
---Clipping Display
LED
---Tested Voltage
14.4V
---Tested THD
1%
>75%
---Dimensions - mm
---Signal to Noise
85 dB
---Shipping Weight
12 lbs
